1 - 16 of 16 Posts
First off.
3.4L 1999 Auto Tranny 2WD
I drive it a bit hard. I use Mobil 1 5W-30.
So the change interval is around 5,000 miles for that oil. So the 5,000 mile mark comes around. I begin to drain the oil and its completely black! I was shocked. I guess I was thinking it wouldn't be so dark. The Air Filter was a little dirty but nothing noteable. Now a friend said that meant I'm running lean and the extra carbon is causing the oil to turn black. My gas mileage does suck its around 15 but then again I have a bedcage and 32's. My question's why does oil turn black and should it be that way at 5,000 miles?
Thanks.
You do replace the oil filter right? If not you need to replace the oil filter, without it, it is unable to extract carbon, acid and moisture from the oil which turns it black.
If so, just run a can of seafoam through the block when you change your oil the next time, it could be some sludge built up on the crank case.
Factor said:
First off.
Thanks.
Mine is dark too and always has been. I've never worried about it because color doesn't really have any relation to the condition of the oil. If you're concerned you could always do a "used oil analysis" (UOA).
I LIVE FOR THIS
You hit the nail on the head.
I got one for you, I have been driving for 25 years and changing oil in my family's vehicles longer than that, and I have never changed the oil in any vehicle that wasn't black coming out.
It is perfectly normal, just watch for water bubbles and metal shavings. Do an engine flush before you change the oil and you should be good to go.
BtW doing the engine flush prior to dropping the old oil will really cause the oil to get black
Dude! you just now figured that out? LOL
not many others older than I am, maybe those crusty butts; Grumpy, hytenor, Chris King and Dick Foster!
Actually shannon is older also, but not by much
Rebuilt98 said:
Dude...You're old! lol.
Heck, I've got 27 yrs driving under my stretched belt.
NorCal Chapter Pres
If you want to change the oil at that interval, I recomend using a extended oil filter from a Jeep Liberty. (Mobil 1 part number M1-209). This filter is the same diameter, same everything, but it is 1" longer. This adds about .5-.75 quarts of oil to your system. Now you have more oil, and more filter area. The result is a longer lasting oil...
I go 5,000 with a extended filter, and I wouldn't go a mile more...
I got you both beat, this old goat has 34 years in the rear view. 36 if you count motorcycles :D
Discussion Starter #12
Ok well thanks for all the help. I'll just keep an eye out for particles in the oil and making sure it doesn't smell too burnt.
start running some Marvalous Mystery oil in the gas tank once a month - keep carbon build up down.
Factor said:
First off.
Thanks.
NorCal Chapter Pres
That stuff kicks ass! I use it on my dirtbike all the time, and it really helped reduce the wear on the valves.
1 - 16 of 16 Posts
