YES!
there are three valves you will need to bleed. Use a 10mm open end wrench, and some clear tube, and a small catch pale. Add extra brake fluid to the resivior. Then open the the valve on the right rear tire, attach the tube, line it up with the pale, and have a buddy pump the brake pedal until you see no air coming out of the valve. when you see no air exiting, close the valve mid pump. You'll need to keep an eye on the resivor to make sure it doesn't drain (you can damage it this way). Top it up again, and repeat for the left durm, and once again for the LSPV mounted to the frame, near where the brake line attaches to the frame.
