1 - 11 of 11 Posts
Portman said:
is there any way someone can post a picture of this . . . sorry, very visual person
The clear bulb you can barely see is the parking light, that was there from the factory, the big orange bulb was from the front blinkers, used a hole saw to drill a hole in the corner light housing, dremmelled off the socket from the original blinker light, contoured it to fit on the back of the corner light, done.
"Janster" has a write up on her site about a different way to do it, but it still involves a bit of trimming.
Mudferret,
So you just added the extra bulb to your existing blinker set up? That must have been pretty easy. Any more pics?
Cheers,
P
There are actually multiple different 'blinker mods'. The one illustrated above (commonly called the 'corner blinker mod') puts a blinker in the corner pod. This can be used to augment or replace / relocate the OEM blinker from the bumper. This one requires some tweaking to install a blinker bulb. There's another 'blinker mod' that cross-wires the bumper blinker and a corner lamp so that they alternate blinking when the turn signal is engaged. This one doesn't require corner bulb replacement.
· Premium Member
Havent seen that yet personally. Everyone i know that has done it has done so due to the addition a a front bumper in order to retain front turn signals.
Yeah I figured as much just thought I ask. I'll see what I can come up with on my own.
1 - 11 of 11 Posts
