Up to 2", I've been told you don't need one. I'm not running one with a 1 1/2" AAL and have 0 problems. Try it first? Add later if needed.VaTaco1 said:I'm looking to do a 2" AAL in the rear, w/ new shocks. Where can I get a BPV relocation kit? Do I need one?![]()
http://www.tacomaterritory.com/forum/showthread.php?t=3192VaTaco1 said:I'm looking to do a 2" AAL in the rear, w/ new shocks. Where can I get a BPV relocation kit? Do I need one?![]()
Do you know what size holes, bolts are needed?KStacoma said:you basically need to extend the mount on the axle the amount of lift you are adding so for you 2". I just went and got a piece of flat steel and drilled holes in it and put it in there. Nothing fancy, whatever will do the job.
grillmasterp said:
You will need a bracket to accomodate the amount that you lifted. In your case 1.5" inches.anestech* said:So, with a 1.5" lift, you wouldn't need a long BPV bracket?
Yeah, the rear brakes could lock up much more easily, which could be a bad thing.03trdblack said:Here's a hypthetical situation....say you wanna get more breaking ability and you make a BPV valve that is LONGER than your lift. Would it think the bed is full of stuff and make the rear brakes help out more? Any downsides to this?
How would the rear brakes lock up w/ anti-lock brakes? Or is that just for the front brakes?anestech* said:Yeah, the rear brakes could lock up much more easily, which could be a bad thing.
But what about just a little bit, say a 2" BPV bracket lift for just a 1.5" lift???
http://www.tacomaterritory.com/forum/showthread.php?t=3192![]()
Well, then they would do the juddering thing, which is also not as good as braking with maximum traction. When the BPV is adjusted correctly, it tries to get the back brakes to do the maximum thay can when the fronts are doing the maximum they can, based on the weight distribution of the truck. Going either side of this unbalances it, one end reaches it's maximum braking before the other. The ABS would possibly be better stopping distance than locking up (or maybe not, maybe just controlled), but maximum braking is the best if you can achieve it.03trdblack said:How would the rear brakes lock up w/ anti-lock brakes? Or is that just for the front brakes?
nothing unless you go too far and have the brakes locking up to easy not to mention possible overheating the rear brakes and increased wear on the shoes.03trdblack said:Here's a hypthetical situation....say you wanna get more breaking ability and you make a BPV valve that is LONGER than your lift. Would it think the bed is full of stuff and make the rear brakes help out more? Any downsides to this?
