1 - 17 of 17 Posts
my e-brake light comes on during turns and fast take-offs, low fluid, bad sensor, or brake hanging up?? any ideas?? :banghead:
Try bleeding the brakes, If there is air in the system it make the computer think that the brakes are on causing the brake lights to stay on. Two it will cause the brake pedal to drop just enough to set off the light
You answered your own querstion: L o w F l u i d :banghead:
Thanks for spelling "brake" correctly.... :)
My comes on and off and sometimes just stays. My fluid level is alright and the brakes were bled when I put in new pads recently so that is taken care of. I think that the e-brake can just tend to stick a bit, I know that other people besides me have had it stay on when nothing in fact is wrong.
Check fluid and also spray some lubricant on the E-brake return spring under the truck on the drivers side inside frame rail.
sexy.taco said:
someone should PM Angry this thread... lol! :lmao:
I didnt know there was a brake fluid reservoir till recently. I thought it was permantly filled from the factory with Toyota Certified Fluid.
Once I found the reservoir, I finally was able to take the black tape off my dash that used to cover that brake light.
Toyota charged me $125 to fill it though. That damn Toyota Fluid is expensive!
Just wait till it starts smoking under the hood and you have to get them to put stuff in the motor to make it stop.
I've got the same problem ('04 TRD taco). The resivour is full, and i've held the e-brake handle in and cycled it w/ the light staying on. it comes on during bumpy/fast driving (even w/ the handle held in (the swith is activated by the rod attatched to the handle))
mine dose this to but it is because the e brake leaver comes off of the back sensor so next time it happens just wiggle it around a little or push it in a little and it will turn right off i also think that there is a little spring that is worn out a little
Mine did that for a long time. It was a bad sensor in the reservoir. You can't just get the sensor alone, you have to replace the whole reservoir ($93 if I remember correctly). Now that I've done that the light only comes on when I apply the E-brake.
Cory
you could check and see if you have some slack on the emergency brake cable along frame under the cab. i adjusted my e-brake cable and my light has gone out. works wonders. when i put new rear brakes on my truck i will adjust it back out.
there may be more to this then just adding fluid.
Your pads may need replaced. if their almost gone this will cause your fluid level to drop because they wont retract the entire way.
Let us know what you find
I have had this problem as well , the emergency brake needed to be adjusted.
Also if you have a manual tranny, if the clutch is getting old and wearinging down or your master/slave cylindar start to leak that reservoir can run low and that will trigger the brake light fluid as well...
Good luck!
.... if the clutch is getting old and wearinging down or your master/slave cylindar start to leak that reservoir can run low and that will trigger the brake light fluid as well...
Really? Is this true? I didn't think there was a sensor on the master/slave.... Learned somethin' new maybe...
1 - 17 of 17 Posts
