1 - 20 of 69 Posts
So today I was fixing up my Manual Hub Spindles, and getting them ready for installation on my truck.
I removed the UBJ's, LBJ's, and all the studs for the manual hubs - they were warped, and bent, and fucked up pretty good.
So after I removed all the old gnarly studs, I decided to chase out the threads in the holes before installing the new studs.
I went to ACE, just to buy the tap I needed. 8mm, 1.25 pitch.
YES - I KNOW HOW TO USE A TAP!
I was on my LAST hole (12 of 12) and the god-damn, son-of-a-bitch, mother fucking slut whore tap broke off in the hole.
I have tried everything I can think of, and I can't get it out, and the high-carbon steel tap is too hard to drill out.
I've tried breaking it, screwing it out, drilling it out. NOTHING! Won't budge.
Any suggestions?
use a q-tip and put some vaseline on the remaining threads...then try some JB weld; glue something onto the tap...the vaseline will help keep the good threads from getting JB weld on them. Sounds *******, but it might work.
Obviously after JB dries, try to back out the tap.
beat it some more and break it up, thats the only way i have ever been able to get a broken tap out. I have a bunch of valves out of older diesel motors that i use for punches, they always seem to do the job.
They make a special little tool for removing broken taps. It looks like a two prong fork that you stick in the hole along both sides of the tap and turn it out. Should be able to find one right next to the taps at the store
Those things don't work. It's a waste of money, just my opinion from personal experience, of course.
--Scott
2019 4RUNNER TRD Off-Road
I would beat on it more with a center punch. I have not meet a tap that I have not been able to break. ;)
Hey man,
If you have DREMEL then you can use a Dental Burr to cut it out and break it up. You can go to your local dentist and ask them for their used Dental Burrs. If you tell them what your going to use it for they will usually jut hand them over. You can also use a Diamond bit for DREMEL which is same as the Dental Burr but you will have search the hardware stores for this. Carbide bits for DREMEL also work. All of these will take time, but you will be able to eventually get it out.
If you have some threads sticking out cut a slot in the tap and use a screwdriver.
I have used the Dental Burr method and it works great.
Good Luck
VTacoma
mojavehanna said:
Very carefully tack weld a 8mm bolt to the end of it with a MIG welder, then use a wrench to turn the bolt/ tap out. Just dont weld the tap to the part and it should work great.
x2!
Left hand drill bit- whether it will drill it or not.
A drill bit isn't going to touch the hardened tool steel that the tap is made from. All you'll do is dull the drill bit and get more pissed off.
X2 on trying the weld trick. The heat should help loosen it up too.
If the welding trick doesn't work. Busting them up is the last resort because of thread damage.
At least it's not a blind hole so he can get at the under side in addition to the top.
if you heat up the out side it will expand and might help
--Scott
bummer cuz I was thinking of getting one of those :(
1 - 20 of 69 Posts
