1 - 16 of 16 Posts
Anyone have one on their non-lifted 2001-2004 Tacoma? I was really wanting to get one . Looks great and very funtional. I was wondering if they would work on a non-lifted Taco. Mine is still under warranty and i am very leary of messing with warranty stuff becasue all the problems dealers give you and such which is why i will wait and lift it after warranty goes out .
ohio03trdtaco said:
You will be fine with it. I have skid and belly pan hanging under my truck with bolt on sliders as well.
Is yours lifted?
are the skids and pan from Budbuilt?
you should cut and trim your front plastic valence like i did and relocate your front turn signals, your truck looks good.
2003 Tacoma trd extra cab v6 no lift cbi bolt on sliders, bud built IFS skid plate and belly pan.
Sorry kind of thought my post was a bit harsh.
Your truck will be fine with the skid plate. My truck has almost 200 lbs of extra weight on it and is starting to sag a bit. I will be putting a lift on it soon do to my suspension sag.
Discussion Starter · #9 ·
Hey not harsh at all. Thanks for the information .Helped a bunch! My birthday is coming up and i want to "try and give my wife a hint" for my birthday. :rolleyes:
Discussion Starter · #10 ·
does it use the stock skid plate screws or do you have to drill and tap new ones?
ohio03trdtaco said:
My truck has almost 200 lbs of extra weight on it .
Very good point. Although i don't have this set up myself, i believe you should consider the weight you are adding to the truck. You might need a suspension upgrade eventually to compensate.
1 - 16 of 16 Posts
