Front
Brand new Trail Gear True Tacoma width driver drop front housing. Welded lower link brackets and one upper link. Also has large fill/inspection hole
Brand new never installed Trail Gear axle seals
Brand Trail Gear steering stops not installed
The following parts are used
Used Trail Gear Dirty 30's with inner shafts
Trail Gear 6 shooter knuckles
Trail Gear 6 shooter arms drilled out for heims
Trail Gear trunion Eliminators
IFS bearing hubs
FROR brake bracket
2004-2006 Drilled and slotted rotors
Genuine Toyota Tundra 231mm calipers with Hawk pads
ARP wheels studs
Trail Gear drive flanges
Low pinion 3rd member with brand new G2 5.29 gears w/used Detroit locker
Axles, 3rd member, seals, and steering stops are not installed
No shock mounts
$2500 OBO
Rear
Trail Gear IFS width rear axle
Stock shafts
Trail Gear brake kit with Hawk pads
1.5 or 2.0 spacers (I will need to confirm what size)
Trail Gear 5.29 gears with Detroit locker
Trail Gear upper truss
Inspection/fill hole
Set up for 4link rear
$1200 OBO
Prefer local pick up, or can deliver to KOH with a deposit or paid in full. I'll take some photos tonight. I hardly get on this site, so the best way to contact me would be by email or phone
woody toyota @ SBC Global . Net (take out the spaces)
1 (four o 8) Seven7two dash 9four88
Located in Santa Clara
IFS bearing hubs
FROR brake bracket
ARP wheels studs
No shock mounts
$2500 OBO
Rear
Stock shafts
$1200 OBO
