1 - 3 of 3 Posts
Barnes 4wd Bumper Clevis Mounts​
Our bumper clevises are cut from ¾” A50 US steel and have a 7/8” bore. The 7/8” bore will accommodate a ¾” shackle clevis and with a good ¾” clevis being rated at over 62,000 lbs they will more than do the job. These d-ring mounts are 3 ¼” long and can be welded through your bumper or attach directly to your frame. You could weld these through a 3/16” thick plate bumper and through a ¾” backing plate and the clevis would still not touch the bumper. Some companies do make longer versions but we have found that making them longer than they need to be just forces too much leverage on the mounting surface. Barnes 4wd bumper clevises are sold in pairs.
Discussion Starter #2
Our bumper clevis mounts are made in the USA and always in stock.
Find them HERE and use them on your own bumpers or to attach clevis mounts to your chassis.​
If you are building your own bumper or modifying one you already have, check out our Bumper Clevis Mounts. They sell for only 16.88 per pair!
1 - 3 of 3 Posts
