1 - 2 of 2 Posts
I am going to be ordering an all pro front bumper. I want to put in fog lights and driving lights. I was thinking of using PIAA 510's, would that be a good choice for fogs and driving lights? Any good ideas on how to hook them up to work with the high/low beams?
For '05+ Taco, locate the 1/2" split cable tubing behind the left headlight assembly and pull out the small green wire. Use your test light to make sure it's hot when you turn the parking lights on. Use the tap (in the package with the wire ties) to connect the switch's +12V source wire to it. Fogs/Drivers will work with the park/headlight switch in any position but "off."
1 - 2 of 2 Posts
