snowchucker said:
lookin good....but god damn that looks like a crap load of work.
I will get more pictures of the dash up close, it was very very very hard to route threw it, because i wanted to keep it as close to stock as possible i had to do it differently than normal... its still strong its just different.
first thing I had to do was seperate teh A piller into two halves, the first half is the top and second is below the dash line. this is because of routing threw the electrical and the passenger side of the truck. The passenger side I had to put two bends total in teh lower tube to route around some select components. on the drivers it was pretty much the same, it was alot of guess work as to the bends, i would bend then try then bend again until it fit right. they are still pretty straight, it was just a small routing issue. then ontop of those i ran 1 bar from one side to the other, this bar had to have a slight bend in it for the stock dash bar. There is a stock .90 wall tube in the dash, i had to notch this tube on the drivers side to get anything to line up, after i notched it it was weak, so i got some exhaust tubing and cut it in half and made a patch, this patch made it about 10x stronger than what it felt like stock! basically i ended up patching from the hole to the cage bar then backto the hole again. (i will take a closeup of this)
the A piller bars are not perfectly straight with the A pillers, they do come back a little, I did the best i could and it came out pretty decent.
overall I would say its comfortable up front, the way i routed into the floor up front made it so i didnt lose any legroom at all.
