man i just ordered my wheels. i got eagle 117's 15x8's with 3.75 back spacing for my 96 ext cab. will i need to grind? i thought this would be an easy fit with no problems. i am starting to read all these post about caliper grinding and i am concerned. :confused: steer me in the right direction and calm my nerves for me :eek:
I'm not familiar with that paticular wheel but my 15x8 rockcralwer lock wheels w/3.75" backspacing required me to shave the caliper a few mm's with a dremel w/a sanding drum on it, so obviously it wasn't a big job or anything. My wheel has D shaped stamped holes however and those seem to be what causes the rubbing so unless yours are cast so that they have a ridge extending out of the wheel pattern to the back you should be fine.
· Not really here...
Some Eagle's rub and some don't. The wheels KStacoma was talking about are steel, so they're a little different, because they're stamped. I have Eagle 058's, and I had to grind a small amount off the calipers. If you're worried about grinding your calipers, you could look into getting a 1/4" wheel spacer to move the wheels out a tad. OR, since you just ordered your wheels, you could possibly cancel the order and find some rims that will not have any fitment issues.
What about...
US Wheels 97 Series Chrome Modular series, will they rub?
-Dennis Stiles
-Dennis Stiles
I looked those up and the picture shows 10 Round holes, they dont look like all the types i've seen that rub on it. Mine for example had the D shaped stamped holes that taper into the back of the wheel. Those i'd say will not need any grindage.
