I go some camburg coilovers last week, and want to raise the truck a little higher. There is only about an inch of thread showing so I thinking I didnt get much lift at all. Forgot to measure before the install. CV boots look good right now as it is not even close to touching.
Question is how do you adjust them. How to you loosen the sleeve so you can use the spanner wrench. Which direction to turn to lift. Also is there any correlation between the amount of thread that is showing and the amount of lift.
