Hey guys. I thought I would start a thread showing some pics of my Camburg install, mostly so I can ask the experienced guys questions and keep all the info in one post. Here are the specs:
2001 ext cab 4wd TRD
Camburg long travel kit, old style with upper ball joints
ORS manual hub conversion
Are you guys running swaybars? The Camburg kit has a tab for it but it looks like the swaybar will hit the tierod boot.
Reservoir mounts. I'm going to try mounting them behind the wheel to protect them from rocks etc. Hopefully the tire won't rub on them, but from looking at it in the garage I think it will clear.
Anyone else tie their brake line to the spindle gusset like this?
I also shimmed the bumpstops down about 1/4" using washers because I noticed most guys are running a spacer there. Does this sound right?
