Hey guys thought I'd share this here. It was posted up over at ExPo. Awesome!!
It features lights, custom bumpers, dual batteries, hot shower, 22 gallon water tank 39 gallons fuel, engel, honda generator, full kitchen, tent suystem, hard case mounts on top rack, compressor system ome suspension w airbag, 33" tires dual arb lockers, manual tranny propane tanks, and a whole lot more. The system will be offered as a complete buy it and drive truck with plans for a diy kit.
In this image you will see the tent covered and the rear flood lights. You can also see the rear kitchen bin. It has 2 burner stove, spice rack, plates, bowls, cups, utensils, cutlery and more in it. You can also see the l.e.d. tail lights.
A front shot shows the custom bumper and winch set up.
This gives you a perspective against the trailer system. Note the taller bin on the truck and matching wheels on the trailer the truck and trailer each can carry a matching spare tire no problem.
And here are the shots set up and deployed.
Note the Pelican cases mounted up top forward of the tent. You can get to your clothes and stuff from inside the tent this way.
Here you can see the tent with the drop down room. The drop room features a zip down door for all weather kitchen access. You can also see the Engel fridge which is on a custom slide as well here.
A front angle same side. Keep in mind there are some zip on awnings that will run down the side of the truck/tent when deplyed. They can be put on both sides.
Close up of drivers side bin system.Note the Kitadyne expedition water filter and hot water shower systems. You can also see the side awning rolled up.
