1 - 11 of 11 Posts
I was wanting to know if I could put an add-a-leaf kit in my truck, while keeping my 1.5" procomp block?
my rearend seems to be sagging slightly, and I would like to raise it up a little bit. I figured that the aal would do that cheap and easily.
thanks
thanks
Yes, and the AAL will eliminate any chance of axle wrap that the block might've been contributing to.
· Administrator
Not so fast there. My AAL helps keep the axle wrap in check, but I still have axle wrap. AALs aren't the miracle fix all to axle wrap, they just keep it minimized.
Your too fast, i was about to say the same thing. Helps, don't always fix
You're both fast, and right. Should've chosen my words more carefully.
thanks
blocks and AAL would stiffen up ur ride a lot...you should consider on getting a full leaf pack..from all-pro..it's about 300 for a 3" leaf pack springs..and you'll like it better with that block and AAL combo.. :explode:
· Long lost Taco Owner
Blocks do not change the ride any, only the AAL
Discussion Starter · #11 ·
Every one thanks a bunch. That is what I was hoping that it would raise me up a little in the rear and possible stiffen the rearend a little.
I just wanted to tap the wealth of knowledge on the TTORA site before I did anything.
If a person had time they could publish topics on this site a probably sell a manual to help intermediate knowledge level guys like me, a sort of TTORA trouble shooting bible.
thanks again :D
1 - 11 of 11 Posts
