I have an 04' Tacoma Xtra cab 4x4 and everyone keeps telling me that I cannot exceed 2" of lift because if will cause major vibration at highway speeds, unless I convert to manual hubs. Is this true? and if so is there any way to get around it.
Assuming youre talking about a spacer or coilover lift, you should be able to go up to 3" without vibration problems, some will recommend a "diff drop" kit, and I have one on my truck although I have noticed no difference with or without it. I have 3" of lift on my 02 ducab and have no vibration trouble...
Good Luck, and Have fun
Doug
It's because it will put your CV joints at a bad angle and cause them to wear and fail prematurely. You should definatly do a search on this one i think there is lots of info on here, there is a way to get around it with a diff drop bracket or diff drop spacers which lowers your front differential and corrects the angles of your cv shafts. I recommend going to this site and reading this page to give you a general understanding then after that continue to learn by reading through past post and using the search function to research the lift you decide is best for you.
http://www.customtacos.com/tech/index.php?page=index_v2&id=137&c=10
Ban Count: 12
People have gone 3" without any problems. If you have vibrations, then you'll need to check your driveshaft, carrier bearing, and/or alignment. (you'll want to get a re-alignment after the lift anyways...
i have 3" toytec spacers in the front...and i put in the diff drop... i dont know if that helped or not..but since it's cheap...i don't see why not to try it out..my friend and i didnt' finnish the rear...so i'm about 1 or 1.5" higher in the front..but i haven't felt any vibration on my tacoma..
it's a 04 v6 extra cab..5spd..hope that helps a little...
where do you live in charlotte? i live in the south part..like around ballentyne
I have the 3.5" Fabtech Coil over kit, and the 1" Diff drop spacer, i have no vibration, or anything, you should be good.
