I was wondering how do you change the fluids for the f/r differtial, t - case and tranny, I remember their being a website with the size of the sockets needed and the locations of the bolts. Also what types of fluids are people using?
Crawl under there and take the skidplate off, you'll be able to see the drain and fill plugs real easy. Just make sure you can loosen the fill plug before you drain your fluids. The diffs hold like a quart and a half or so if I remember, but everything gets filled until fluid is level with the fill hole, just squirt it in until it comes out the fill hole, then you're good to go.
--Scott
thanks your write up was good. It says you are an authorized amsoil dealer, I am interested in some fluids.
