1 - 3 of 3 Posts
Any recs on capacitors? I'm going to be doing an all kicker system and wanted some kicker caps to go with, but i didn't see any on their website. Probably going to go with a Mono amp for the sub(s) and a 4ch for the components. Not sure on wattages yet though.
-Thanks
Instead of a capacitor I would spend the money on a good battery, clamps, and good wiring. Then do "the big 3". Which is basically a bigger alternator charging cable to the battery, bigger ground from the battery to chassis, and bigger ground from the engine block to the chassis. This will improve your current flow. Then if you still have some money burning a hole in your pocket look into an AlumaPro C.A.P. http://www.carsound.com/review_archive/in_car/alumapro_cap5.shtml
Retired
I have a Blackmore 0.5 farad capacitor with digital readout and timer. All 4-gauge wire from battery to cap to amp to ground. Amp is only about 440 watts.
1 - 3 of 3 Posts
