1 - 16 of 16 Posts
I want to add a CB to my FJ. Where can I get one installed right?
Do it yourself. Guaranteed to be done your way everytime. Really though, it's quite easy. Anybody can do it. Just do some searches here and on Google. Remember, the key to a good cb is the antenna. Any cheap radio will do, spend the money on the antenna.
STITCH - Come and Take it!
Read this thread on CB install and operation.
http://www.tacomaworld.com/forum/audio-video/280574-cb-radio-information-installation.html
I know you mentioned to have someone do it for you.
But you really can do it yourself.
You could host a WAT, Wrench-a-ton, where you can either invite or go to a member's place to install the CB.
ALL you would have to do is provide food &drinks.
Easy way to learn, so if something went wrong, you could fix it yourself.
I'm a bit confused here. Overall I need a CB & microphone, speaker, antenna cable, antenna, antenna mount and ? ,I got the All Pro bracket, Fire Stick II, but do I need another bracket to connect the antenna to the mount and cable? And if so are either of these acceptable?
Mounting spring
Heavy duty mount
Just make sure you set up the antenna correctly. I fried my radio because my ground sucked
1 - 16 of 16 Posts
