1 - 20 of 28 Posts
Ive been searching for a CB radio that will fit in the DIN slot under the CD player, like the Cobra 18 WXST II, but also has PA capabilities. I am aware of the small CB's w/ PA's that can be mounted in the ash tray location, but I am not really interested in going that route. Ive searched everywhere but havent found anything. I would appreciate any recommendations.
I mounted a corbra 18 WXST II just under my pioneer stereo. I used a screw from each side of the CB . lined it up to the stock tacoma radio mount and tightened it up . work great! the speaker in the front works great too.
That actually seems to be one of the only CB's that fits in that location. I am seriously considering purchasing one, but it does not have the PA feature that I am looking for.
Uniden PRO520XL - This cb will fit, has PA capablities, works great and is a good deal. I had one in my 4Runner and plan on getting another for my Tacoma. My friends also run this cb, I have never heard any complaints.
Sounds like its a pretty good CB. Its a shame it doesnt have the PA function that I am looking for. If it did, I would definitely be ditching my Cobra 25 NWST to buy one.
one last thing, i just check the pdf file for the corbra 18 WXST II and it has a speaker out jack in the back.B.
Rear Panel
1. Antenna Connector. This female connector permits
connection of the transmission line cable male connector
to the transceiver.
2. External Speaker. The External Speaker Jack is used
for remote receiver monitoring. The external speaker
should have 8-ohm impedance and be rated to handle
at least 4.0 watts. When the external speaker is
plugged in, the internal speaker is automatically disconnected.
3. Power: This cable is permanently attached to the radio.
If you wish to remove the radio after installation, disconnect
at fuse holder and ground connector.
· Ban Count: 12
Anybody have pics of it mounted in the ash tray area?
Discussion Starter · #18 ·
Ive got a Cbora 25 NWST, so the install that Tacozilla did is exactly what I would need to do. Im still a little bit skeptical about cutting into my AC piping, as this is still my daily driver. I may have to do it anyway, that install looks really good.
Cutting into your a/c line??? I have a huge radioshack CB and all i had to do was take a dremel to a small part of my bottom left and right stereo mount. That CB fits in there so tight and looks good too. Check out that faceplate I made on my computer! I got my CB at a garage sale for $5.00, I mean what a deal. Now I have to figure out where I should mount my mic?
Discussion Starter · #20 ·
You didnt happen to take any measurements of the CB before you installed it did you? That looks to be the exact same width as the Cobra 29 WX NW ST, but much shorter. I am amazed that a CB that wide is short enough to fit in the dash.
1 - 20 of 28 Posts
