STITCH - Come and Take it!
Well I have completed the webpage on my write up on the installation of my new CBI Heavy Duty Clamp-on Sliders for my 2001 Taco Double Cab!
Please review and if you have any questions or suggestions, post here or email me.
Enjoy!
CBI Install on TejasYOTA
My thanks to Steve at CBI for making a quality product and painting the sucka! :)
I'm planning to do that tomorrow, when the temp gets back into the 60's :)
I will also see if I can knock down the sharp edges with a wood block or the flat surface of a steel, so I could minimize the scraping factor of my legs and my wifes!
Sliders
Sliders look good.
I have some CBI clamp ons on my 98 x-cab. The only thing that I don't like about them is that the top of some of the clamps rub the bottom of the cab floor pan. That rubbing makes noise when you turn, go over bumps, etc. There is just not enough clearance between the frame and the cab body unless you have a lift.
Do you have that same problem with your set up?
I wedged some pieces of rubber matting in those areas to stop the metal to metal contact. But all in all they are great. My powder coating seems to be holding up well.
TACO300 said:
...that the top of some of the clamps rub the bottom of the cab floor pan. That rubbing makes noise when you turn, go over bumps, etc. There is just not enough clearance between the frame and the cab body unless you have a lift.
I wedged some pieces of rubber matting in those areas to stop the metal to metal contact...
Yes the top of some of the Clamp-ons do rub the top of the floor board.
No, I have not heard the noise yet.
I think other than using a rubber mat is to do an 1-inch body lift.
Thanks for the tip!
