Why bother? look at the old fox/fabtech coilovers they had huge problems with it, i know I had a set with those problems.. they switched to heim for a reason..TomTRD said:has anyone changed the metal hiem joint that connects SAWs/Kings coilovers to the lower control arm from metal to polyurathane? If someone has done this, got any pics/info or where you can get it? Thanks.
Damn... when i ordered the replacement metal hiem joints from Ryan @ SAWs, it cost me $30.....drabnor said:i'm with opp, why?
if the heim goes bad, replace it for $13.99
was that for both of them?TomTRD said:Damn... when i ordered the replacement metal hiem joints from Ryan @ SAWs, it cost me $30.....![]()
I thought the Fabtech coilover problem was cause they used bad rubber joints and fixed it with polyurathane ones to original owners... then on the next gen from Fabtech they upgraded to metal hiem joints....?DesertTRD said:Why bother? look at the old fox/fabtech coilovers they had huge problems with it, i know I had a set with those problems.. they switched to heim for a reason..
