I came across this article a while back and I was pretty impressed. It gives a very easy procedure for finding the theoretical angles at which your truck will roll rover . . . Next weekend I am going to drop the 2" body lift so I want to find my roll-over angles before and after to see if they improved. . . .
Note 1: Yes I know that the article is for a jeep. But of course it will apply to trucks just the same. If it's too painful to read, just substitute "Tacoma" everywhere you see "jeep."
Note 2: I know that other factors can add to the cause of a roll-over such as momentum (if you hit an obstacle going too fast), terrain (if a wheel falls in a mudhole or rocks suddenly slip underneath), etc. . . . So this is assuming a static situation where you are barely moving and the surface underneath is completely firm. . ..
But anyhow, I figure it's nice to at least know the maximum static angles that I can reach before I roll-over. Then I have some sort of a basis to go by when I find myself in a very off-camber spot . . .
So tomorrow I'm thinking that I will just use a hi-lift jack on both sides of the truck and lift the truck up by the wheels using the "lift mate" that attaches to the wheels for lifting. . . . The only problem is that I only have one jack and lift mate, so I will need one for other side. Anyone local want to help out with that?. . .
After that I need to get an inclinometer so I can watch my angles on the trail and see if I'm getting close to the dangerous angles. . . . I only see these on E-bay. Anyone have a recommendation for one?
