Check your nuts often!!
This is cross posted from the Cali board.. figured ya all could use a reminder too! Original post is at:
(http://forums.delphiforums.com/CaliforniaOffRd/messages?msg=3700.1)
Fun morning so far.. I got about halfway to work, and my truck started vibrating real bad when I let off the gas.. it was getting worse and worse.. pulled over, check the rear, coundn't find anything wrong.. started going again, and it got real bad.. at this point it sounds and feels like something in my third member let loose.. since I wasn't far from home, limped it via surface streets back home.. went under it, still could see anything visable with the rear.. I was getting ready to drain the third when I checked the spin on the drive shaft.. and noticed it was feeling loose.. followed the looseness up the shaft, and then found this:
Holy crap, 3 of the 4 flang bolts were gone, the 4th was on it's way.. if that 4th had let loose on the free way, my drive shaft would have pole volted my rear to who knows where, and I'm pretty sure i'd be looking at major damage and even an acident at 50mph.. I lucked out and the one bolt held until I got home and found it.. but barley..
I'm pretty good about going around and checking my bolts, and using blue locktight on them.. but I hadn't done my check in awhile, and I hadn't put blue locktight on these since I had the driveshaft rebuilt awhile back.. stupid me.. So take it as a warning, check all your bolts from time to time, and use that blue locktight!!
I just have to find a way down to a hardware store now and buy me 4 new bolts, hopefully the vibrations didn't do any damage to the u-joints or the 3rd.. but dang I'm lucky..
