1 - 8 of 8 Posts
I have an 04 TRD . Was wondering if anybody knows if 99 chevy silverado wheels(rims) will fit my tacoma. Silverados are 6 lug also. They are OEM wheels if that makes any difference.
The centerbore is too small on the oem chevy rims. Toyota has a fairly large hub diameter 108 mm I believe. About 4 1/4 inches.
Oh well.. Thanks for the quick response
emack8 said:
I am running wheels that came off of a 92 chevy silverado 4x4 on my 98 tacoma
No rubbing or fitting problems??? Did you have to modify the wheels at all? are these alluminum wheels or the steel wheels?
Late model (I think 94 and up) are a 6 lug metric pattern, with wicked backspacing and a small center hub.
When you look at older rims, you have to look at the center hub size.
We have 6 lug on a 5.5" pattern.
Good luck finding some rims.
Daniel
His 98 probably has manual hubs also whick are a little bit smaller than the add.
1 - 8 of 8 Posts
