1 - 9 of 9 Posts
Hello,
Like all of you I like to take my 4x4 off roading. I just got an 05 and the 2nd weekend I had it it was in the mud. I also like to keep it clean as it is my daily driver. Leads to my question, cleaning. I can get the under carrige and body pretty clean even after a hard weekend wheeling. Under the hood is a different story. There is mud all over under the hood. I have read its better to use a regular hose rather than a pressure washer so water does not get forced into areas its not supposed to be. My MAIN concern is the electrical system. I can see the obvious things i need to cover like fuse box, battery terminals, alternator, etc. but what else do I really need to watch out for when I start under the hood with a hose. Thanks for all the help.
i havent seent the 05's engine compartment, but on my 03 I just blast away. Its fine to get the electrical shit and alternator wet, just dont keep the pressurewasher on it for 5 minutes. I pressure wash it about every 3 or 4 months jsut to keep it looking good. have fun.
On my 01, the only thing I cover are my HID ballasts. As J-man said it's all good. The fuse box should have seals and it's ok to get the alternator wet. I cover my battery most of the time but it's not necessary unless you have open fuse blocks connected at the battery. On my Integra, I had to cover the distrubutor as well (most important) but my Taco (as well as yours) have coil packs so no worries. I start the engine right after I'm done rinsing to help dry off the water.
I cover the alarm horn and make sure I cannot spray water into the air filter. I had the deck plate mod before putting in the Volant cold air intake; I would put the plate in to close the airbox. If the engine compartment is really dirty, I would spray it with Simple Green, let it sit a few minutes then rinse it clean with plain water. Do this on a cool / cold engine if at all possible.
There be a serious lack of seals on the '03 fuse box. Might be hard to get water in it when washing, but anytime else is fair game...
One thing you can do for prevention is go to Lowes, Home Depot and buy some shower pan liner and use it to make a fender liner around the upper arm and strut. That area is wide open and allows everything but money to get in the engine compartment. Worked for me.
Only problems with using a garden hose or pressure washer is that sometimes it will trigger the check engine light and set a missfire code, ecspecially on newer model like 2005. Use basic degreaser and always let the engine run will you are cleaning it.
i work in a detail shop and I have cleaned engines out of many diffrent cars and I use a pressure washer. The only time you will have a problem is if you have a crack or lose seal on your distributor and seeing as you have a brand new truck, blast away. I have an 01 and i clean my engine once a week with no problems.
hey everyone. I'm new here, so help me out if i do anything wrong. anyways, i work at a car wash and i clean my engine and see many other people clean their engines with the pressure washer. when i clean mine, i spray the car wash engine and tire cleaner on it, let is soak in ( i usually clean the truck while it is soaking), then go back to the engine and spray away. i don't keep it pounding on the engine, but instead use kind of a sweeping motion. after that, when it is dry, i spray armor all, or tire foam on it. makes it look real good.
1 - 9 of 9 Posts
