After 226,000 miles, my clutch master is finally dying on me. I was losing pressure on the clutch and sometimes couldn't release the clutch while driving. One of the main reasons was due to the contaimination of the brake fluid and excess water in the fluid. I perform all my own maintenance, including the 30k and 60k major maintenance intervals. One of the things I neglected was the clutch. When I finally flushed the fluid a few days ago, it was a dark brown color with lots of small dirt particles. Not good.
I already had a slave cylinder rebuild kit, so I removed the slave and checked it out. Bleeder valve was clogged, inner cylinder was rusted and had lots of dirt and setiment. Flushed everything out good, cleaned and honed the slave and re-installed. Worked fine for a day then the problem came back. The seals in the master cylinder must be going out.
I just ordered a new master cylinder and a new slave cylinder. Cost $80 for the pair. I'll be installing them this weekend.
The moral of the story - Be sure to flush your clutch fluid every 60k miles when you do the same to the brakes.
