Clutch pedal Bearing
So I was looking and thinking and it dawned on me that if I could get a bearing in there it would fix the hell out of this problem!
So I went down to the bearing store (seriously) and found a small bearing with an ID slightly larger than the ID of the U-bushing and the OD was whatever the bearing came with it didnt really matter.
So I guess I should tell you now rather than lead you all on that I havent completed this project yet, I have to pull out the spring and see if i can slide the bearing on down around the coilness of it or if that doesnt work Ill try cutting it and welding or splicing it back together... the welding probably wont work very well on this spring steel Anyone have any ideas or questions to help this problem?
