Zintradi said:A while ago I heard about a coil-over assembly that you could add to your rear leaf spring to help with axle wrap.
A traction bar is about all there is that will actually fix the problem. heavier rear springs with a straight overload will also take care of it. price is about the same for either of these.Zintradi said:A while ago I heard about a coil-over assembly that you could add to your rear leaf spring to help with axle wrap. I was wondering if anybody has an Idea of what I'm talking about and what exactly they are called?
No its not a coilover its just a stiff coilspring attached near the center of the spring and the rear end of the leaf pack. So when you springs bend it now fights the coilspring. Not worth it. Get an AAL it'll take away a lot of the axle wrap or get a new spring pack.Zintradi said:A while ago I heard about a coil-over assembly that you could add to your rear leaf spring to help with axle wrap. I was wondering if anybody has an Idea of what I'm talking about and what exactly they are called?
www.budbuilt.comOutback said:Where is this traction bar that mounts to the diff cover advertised???
with all the overloads in place on the OME leafpks you really shouldn't have a problem. Have you checked your rear pinion for any play? grab the driveshaft near the pinion and shake it up/down, side/side. There should be no play at all. Also check your U-bolt torque...should be 90#. Check your carrier bearing for any damage. There will be a lot of play but if the bearing is shot it will be excessively sloppy.Outback said:Do you guys think I really need a traction bar like budbuilt.com sells with my OME lift?? Isn't that reserved for really big lifts and softer springs for better articulation?
I'm more of an expedition wheeler with the family in my Taco. I have my FJ40 for hardcore wheelin' and rocks & such.
But this axle wrap at every stop light is annoying!!!!
This better be the be-all end-all of my problems for three and a half bills....
Would you do it?
Jody.
