im looking into getting UCA'S from total chaos and DR coilovers. Does anybody have any suggestions and/or advice concerning the UCA'S and shocks.
You should be happy with the set-up. I would just suggest going with the extended DR coilovers if you're going to be doing UCA's as well.
And you may want to search more and stick to the Newbie Tech folder also....
They UCA's "are" supposto work alot better with the coilovers than stock.. Wel I should say, The coilovers and the truck will give you better results if you use the UCA's... Get em. I'm wanting to down the road....
UCA's are a good choice for whatever route you choose to take. They will correct the caster nembers and eliminate the coil to UCA bind at full droop.
ya, im probably going with the extended coilovers
