1 - 13 of 13 Posts
· Split it open-Eat it out!
FS:
Houston area
White 1986 4Runner
currently not running. Needs intake installed, gasket on EGR valve needs to be scrapped off. brand new timing chain (steel rails), water pump, oil pump. fuel filter, master cylinder and Doug Thorley Tri-Y Header. Timing needs to be set, valves have been cold adjusted, will need re-adjusted after start up. Also has almost brand new 31x10.5 BFG A/T's (less than 5K miles). Comes with factory service manual, extra third member (4.10 or 4.30 can't remember) wilwood proportioning valve for rear disc conversion. All electrical works, even the rear window and wiper.
no longer have any time to work on it due to my job, wife is tired of it sitting in the driveway. First $750 takes it.
Pink Taco said:
FS:
Houston area
White 1986 4Runner
Dibs
I'll call you.
I actually thought you would've been the first one to call dibs. Phong has already paid for it, he should pick it up next week sometime.
Mike
Dang, I didn't see the add till today.I have another I am going to get this week, but that would have been a nice one to SAS.I even have the parts saved for a project like that.
· Deal Master
nastynate said:
hehehe.... you should seek some help for your "problem"
Actually got the green light from the SO- So I pulled the trigger.
When I start coming home with a donor/parts trucks for this project, then I will be checking into the Sofa Inn.
I plan to get the 86 runner street legal...and then I will entertain the idea of SFA.
· Don't get Wenzeled
Sweeet.
I have to cure my SO's new-car-need before my own.
All in good time.
1 - 13 of 13 Posts
