Hi did some searching could not find anything. Has anyone converted the narrow band o2 sensor in a 4Runner to the newer wide band sensors. not sure if that is even doable
Thanks John
You would have to run a 01-02 4runner ECU, re-wire the harness, etc. etc. Would likely have to replace the engine wiring harness and adapt it to your body harness. Swap a 01-02 MAF / intake, TPS (possibly), etc.
What are you looking to do with it?
I just thought I'd get better fuel mileage. I didn't think it would be easy
Thanks. John
Nah, fuel mileage will be the same.
a narrowband works best at 14.7, where you get the best mileage, so a wideband will not give your computer better info when at stoich (which is where you get your best mileage).
Do you have a good tune on your URD kit?
Thanks I will try and make it. What time is the meet.
John
