1 - 20 of 24 Posts
Does yours? I just took a 700 mile round trip from home in CT to Dad's in upstate NY. I'm a huge fan of cruise control on trips such as this, but on a few occasions, the cruise shut off when I hit a significant bump in the road. My GF and I pondered whether this is a safety feature, or whether I need to find a fault somewhere. I've only been driving this truck for two weeks, so I don't know!
i have the same thing on my 95. i don't remember it happening until the last two years :confused:
I was told at one time that i needed to get my cruise control cable adjusted by a stealership. Although I never had them do it and never did have any problems, you may want to start there? Look it up in your service manual. Post up what either of you find. :D :D
You know how the cruise deactivates when you use the brakes? Possible over time the pedal gets some play and when you hit a big enought of a bump, it moves enough to trigger the switch. Just a thought...
I have the same problem with mine and it is the pedal switch. It didn't start happening until I removed the pedal spring after the bushing wore out. I couldn't stand the squeeking.
hell my CC works whenever it feels like, I gotta turn it off and on a few times for it to catch... :confused:
i have that problem but for me it's the parking brake. one day the brake got stuck out and it never felt like it went all the way back in after that. well now when i hit bumps the parking brake bounce out enough to disengage the cruise control.
My old truck didn't and this new truck doesnt either.
elliot_irwin said:
your not driving it hard enough out on the trails :p
lol, don't think thats the case for my taco...
I have an 04 with 60,000 and mine works fine, well except for the fact that it allows itself to loose speed then atempts to gain it back by dropping a gear and making the engine scream, dont like to use it at all. Then again may be spoiled, the 502 in the work truck does not even gain many rpm when I have the cruise on and going up some of the hills in the area.
Same thing here. I'm pretty sure Tacomanator nailed it. I noticed if you even so much as tap the clutch on the side, it'll deactivate the CC. I also took out the return spring, and i think the tiny spring i'm using to hold pedal up isn't strong enough, so the small amount of play on the pedal is doing it.
Discussion Starter #14
Tonight I adjusted the brake and clutch switches, and the cruise did not turn off when I hit that one bump that usually shuts it off on my 25 mile drive home from work. Time will tell though, whether tonight's drive was a fluke.
For those who have never done this, there is a switch above both the clutch and brake pedal arms. Loosen the locknut with a 14mm wrench and disconnect the electrical connector. Turn the switch clockwise toward the pedal arm until the button is all the way flush with the body of the switch. Tighten the locknut and reconnect the connector.
my 2000 does it also.
since it was new pulling a steep hill or 75+
just once in a while
hit the resume and it goes back on
Check your brake lights to make sure you didnt turn the switch out to far to activate them. I accidently did that once.
From the owners manual "If the vehicle speed drops 16 km/h (10 mph) below the preset speed, the preset speed will automatically cancel out."
My CC works fine on my 2004, but we will see what happenes when I have 100,000 miles on it.
Discussion Starter #19
Really? I can't see how that's possible. I only turned it toward the pedal until the plunger was flush...
Turning it toward the pedal will make it easier to bump the C/C off if the pedal bounces on bumps. If you get it to far down the pedal wont engage the switch.
1 - 20 of 24 Posts
