1 - 20 of 49 Posts
building some sliders out of 2 1/4'' inch steel tubing with 1 1/2'' square tubing dividers and they are bolt on, will be painted black and topped with diamond plate(for step traction, and style)
Pretty wont matter after you use them a few times :D
Chris-
95% of the people here don't wheel like you and I do, but I agree with you. How many times have we bent or dented DOM sliders?
Tim
I'm planning on running diamond plate on my sliders too.
BTW, has anybody used a single piece of steel for sliders, like a 2.5x6 inch stick, welding some covers at the end and then just welding some brackets to weld to the frame? What would be the downfalls of this design? Weight?
I've seen sliders like this. They would be heavy, and prone to denting unless you used thick wall tube... which would add more weight.
generalee7 said:
Hell no not yet :D I'm waiting to get chromo shafts, ORS cage is gonna get ordered tomorrow :)
Wa wa wa. Just dooooo it!
Weight, weight and then more weight. These aren't steps, these are sliders, designed to protect the body.
Yes i know they are sliders, I have no prob getting in my truck with 2.25 inches of lift as of now. The reason that popped into my head is that I've seen other peoples sliders and they basically have 2-2inch tubes running side by side with some 2 inch square tubing in between them. So i figured that if I used the same tubing thickness that they use, the amount of steel used would be around the same, right? :confused: I have no problem using the square tubing, cutting it, welding and installing. But i figured that it could probably weigh the same. But i guess not.
First off, if you don't know the difference right now you don't need to worry about it.
Second off, if you get to the point where you need to know the difference and are a competant welder/fabricator, when it breaks fucking fix it better.
Third off, what I've read regarding square vs. round is that if you can anticipate the direction of impact, square will take a harder hit before bending whereas round will take it equally well from all sides. My interpretation of this is related to when competant fabricators with alot of experience like Demello make a slider, it is square in the middle and round outside- square takes the hits at right angles, straight up and directly in where the legs run and the round on the outside gets what it gets.
Just build the shit man, plenty of gussets where you make butt joints and when you outgrow them, make some more. This is ain't suspension, its a damn slider.
Speaking from personal experience, you're never going to learn anything worth knowing getting worried to death about bullshit you read on the fucking internet.
Thats not a burn at all. Wgasa and Tim wheel harder than 99% of the people on this board and that is where they are coming from- and their advice is absolutely correct for their application.
1 - 20 of 49 Posts
