Up for sale is a Custom Fabricated 4x4 Long travel Suspension kit
Kit includes
•Tubular Upper Control Arms, 7/8" x 3/4" Chromoly Heims Joints and 1" Vertical Uniball Cups.
•Boxed Lower Control Arms, Prothane bushing pivots, Vertical 1” uniball cups
•Fully-Fabricated Spindles using big bearing Snouts retaining 4x4 by using u-joint style axles. This kit works just like the Solo Motor sports kit.
•Front Snouts w/Hubcap, Bearings, Seals retaining 6×5 1/2 factory tacoma bolt pattern
•Brake rotors with 6-5 1/2" lug pattern, with 5/8" studs
*** Kit will require Custom Fabrication skills to install.
I Built this kit for a 1st Gen Tacoma but then never got around to installing it, and now i need to sell it.
Custom Shock mounts and Coilovers will be required for this kit. Shock length and mounting location will determine expected travel numbers, I estimate with a 12 " travel shock you should be able to get around 14" to 16" inches of travel while retaining 4x4
*** these are extremely well built, 100% GTAW Welded using High Quality material.
They are not painted and still have steel finish at the moment, I have kept wd-40 on these to keep them from rusting.
I hope that someone will be able to use these for their project and save them alot of time and money, and have a Race Ready 4x4 long travel Set up.
$1000 -- OBO
Located in Augusta GA -- Local pickup available
Shipping will be at the buyers expense.
https://dl.dropboxusercontent.com/u/110711279/0106141811.jpg
https://dl.dropboxusercontent.com/u/110711279/0106141812.jpg
https://dl.dropboxusercontent.com/u/110711279/0106141814.jpg
https://dl.dropboxusercontent.com/u/110711279/0106141815a.jpg
https://dl.dropboxusercontent.com/u/110711279/0106141821.jpg
