I recently parted out my 83' longbed. I had made a custom flatbed that I still have. It is 63" at the cab and then tapers out to 73" to cover the tires all the way to the rear. It is only 70" long. It is made from 1"x2" steel tubing with a steel diamond plate deck. It also has triangle diamond plate pieces along the taper, as well as a rear diamond plate skirt that has a recessed license plate holder and lights, and 4 round 4" tail lights. Its still has a spare tires mount and high lift jack mounts attached as well as space next to the cab to intall a tool box. The bed mounted to the stock mounts and can be made to mount to virtually any truck. This thing is heavy duty.
I'm asking $150 for it, local pickup. I'm located on Whidbey Island, WA.
Here is a pick from when I made it.
Here are a couple of pics of it mounted.
Discussion Starter #2
bump
It was built in Austin, TX. But it moved!
bump
