1 - 14 of 14 Posts
bushwackers right...
where are you guys finding them... all i see are for the 95.5 and older?
i have a 97 and need 2" to 3" coverage...
suggestions?
Thanks!
casey
suggestions?
Thanks!
casey
You should be able to find them anywhere that carries Bushwacker. Part # is 31919
suggestions?
Thanks!
casey
In case you haven't actually felt a set of these, they're very hard plastic and because of the way they mount if they hit anything wheeling they'll break. My old Bushwackers were a little bit flexy but these are rigid and have no give. I don't think it will be long before I drag it against a tree or hit it on the ground and shatter one. Something to think about if you plan on wheeling with them. ....Steve
· Premium Member
I've already hit rocks and stuff with mine they have scratches in them but haven't broke yet.
Discussion Starter · #9 ·
Grumpy,
how's that SOA'd rig doing? think i'll go with the xenon one's instead...
not going to make it to azrocks2005... but will be there 2 weeks later... damn! will have the taco... so maybe i can get a few folks together and we can go out somewhere... never be up to that area north of phx just off i17...
take care!
casey
des moines, ia...
I touched a tree with mine and cracked from one of the bolts to the edge of the flare. Not a big deal at all but if I had hit any harder I think it would have wrecked the flare. The way they're mounted there's no way the flare can flex, it will either break or wreck the body panel.
· Premium Member
cmcampbell54 said:
Grumpy,
take care!
casey
des moines, ia...
doing well need to fix couple of issues, hope to be done with that in next few weeks. put up on teh SWboard when your coming to town and I'm sure we'll be able to get together for a run.
· Premium Member
yea I was expecting the mto break but looking in rearview they do flex some.
but I agree it seems they will break quicker then the TRD ones.
Maybe it had something to do with the -18 temperature or the way it hit but mine didn't flex at all. Hopefully I won't be running them into many more trees. .....Steve
1 - 14 of 14 Posts
