1 - 3 of 3 Posts
Can CV type driveshaft be balanced?
I have built front shaft with CV head on the TC side.
I'd like to balance it, but not sure if this can be done. Regular driveshaft has 2 U-Joints and can be fixed mounted for balancing. CV shaft has 3 U-Joints, so if ends are fixed mounted it still has a play due to 3rd U-Joint. Is there a special technique or method for such shafts or they simply unbalancable?
Scared of Slow Speeds
I do not know the exact process to balancing a shaft with a Double Cardan joint but it is possible. We have a local driveshaft shop that high speed balances custom shafts for us. A qualified shop like the one we use should have no issue.
1 - 3 of 3 Posts
