1 - 18 of 18 Posts
The lift shop says I should use shims instead of the diff. drop. Will that work better? I have both available, but want to get rid of my vibration that i have with blocks. What would be in my best interest?
huh??? Diff drop has to do with the front diff but blocks have to do with the rear lift.
Ok tell use what your overall goal with the truck is what lift you are trying to put on and what problems are you trying to get rid of and then we can answer your question.
Shims are just basically used to correct pinion angle.
Pics would help too
My pinion angle did not change with the Dakar installation. I have no vibs at any speeds in 2WD or 4WD. A diff drop is for the front diff, the degree shims are for the rear to correct pinion angle. With the Dakar install, you shouldn't need either as long as you don't add blocks or a longer shackle with the Dakar leaf pack. Heck, my rear brake line had enough slack that I didn't even have to add a rear brake line extension!
oh oh oh the support bearing in the middle of the driveshaft.
either will work. I didn't use anything but if they got them it may not be a bad idea, can't hurt anything.
But if it has not been changed since you have had the truck replacing the bearing wouldn't be a bad idea either
either will work. I didn't use anything but if they got them it may not be a bad idea, can't hurt anything. Edit now that I have read both posts together and I think I know what you are trying to ask, if the guys installing your lift feel that the block is what is causing the vib then yes try to do the samething with shims and see if it goes away. Am I on the right track here or do you still have me in left field.
Discussion Starter · #7 ·
I have an 07' Taco. I hope nothing has to be changed, lol. I had a carrier bearing drop in with my deavers and it made the vibe worse so I took it out. I figured it was designed for the OME springs since it is an OME part. The problem being is that the carrier moves approx. 3/8 of an inch from side to side and I am not sure if it is located where it should be. I centered as best I could, but I am not sure the dead center is where is necessarily should be. I sure hope I didn't start a shit load of problems.
Well do you still have the vibe with out it. If not than I wouldn't worry about it. But I did read in the other post that you are planning on running 315 is that just with the dakar leafs or are you running any other kind of lift in the rear. Didn't know your truck was an 07 so no you sholdn't have to replace the bearing.
Discussion Starter · #9 ·
Just the Dakars. They lift the hell out of the rear end though. They give 2.75 inched of lift and the rear is already 2 inches higher so that makes the rear 4.75 inches higher than stock. I lifted the front 5.5 inches with spindles and coilvovers so the rear should sit exactly 1/2 inch lower which is fine with me.
alright, its pretty early for me so cut some slack but when i was installing my deavers i noticed something that might cause the vibe. ok, you know how your leaves that the main bolt that goes all the way through the leaves at the center of the pack?(top to bottom) Well on your axle there are 3 holes where that bolt will want to drop into. Now if 1 leaf was to drop into the hole in front, while the other dropped in the middle wouldnt that cause a vibration/dog leg? it may have already been discussed, but it was just an obervation i had. id get under the truck and see if the leafs were in the same spot on the axle.
Brock: my axle pad only had one hole, dead center. Curious how you got a choice of 3:confused:
Try the center support bearing drop and the 2 degree shims and see where that gets you. The vibe should be subtle on take off.
It's 11:30!!! Slacker:xbeer2: :xbeer2: :xbeer2: :xbeer2: :xbeer2: :xbeer2:
went to sleep at 7.. lol.
mine had 3 holes on the axle... dunno, but it did because my deavers fell into the front hole the first time and i got all pissed off.
mine had 3 holes on the axle... dunno, but it did because my deavers fell into the front hole the first time and i got all pissed off.[/QUOTE]
No shit! Maybe there was more than one perch being used by toyota. Shit happens.
Cause right now all I have is the carrier bearing drop and it vibrates hella bad.
Yeah, it should have helped. Try the axle shim with the carrier drop shim and see if it helps. I haven't had time to figure mine out after I did the Dakar install. Been too busy at work lately.
1 - 18 of 18 Posts
