The little vacuum valves that move the actuator in the front diff for the ADD system are dead and I am not going to replace them - too much $$.
So that leaves me with needing to work around that system to have 4wd in my T100 again.
There is a good write up on doing this out there where you pull the actuator and use a CV boot clamp to fix the fork to the actuated side, manually slide the sleeve over and then bolt it back up.
Can I just pull the existing vacuum lines that go through the valves, put a vacuum on the passenger side to slide the fork over and then leave it? Ideally I'd like to get this done with the least amount of effort as I am in process of selling the truck. Don't want to half ass it though and screw the next guy.
Moderator
If you are selling it and don't want to screw over the next guy why not leave it as is and tell the buyer what the problem is?
ike - Good question. In my opinion its a lot easier to sell a truck when it doesn't have a laundry list of issues attached to it. Any repair I undertake will be one that I would be comfortable with if I were to keep it. I may actually keep it for a bit longer. It's paid for and I don't have to have a different vehicle right now. Planning for a kid in the near future though so was wanting to get it to the point where it's ready to sell when the right replacement truck comes around.
