1 - 20 of 49 Posts
I know a lot of the guys here have A LOT of experience offroading. So....
I'd like to know any driving skills/tips when driving in the desert, especially when tackling the certain obstacles you find in the dez.
Ive been given a lot of advice when wheeling and i just want people to share their advice. For ex.
On whoops, ive been told, i should tap the throttle consistantly everytime i hit the top of a whoop. Then other people say, "haul ass!, if its a really rough ride youre not going fast enough"...... :confused:
And on DR i was reading about a person who messed up his driveshaft/rear diff b/c he jumped his truck and never let go of the gas pedal.
Then someone told me i should never drive with my thumbs on the steering wheel because bump-steer can jerk the wheel and break my thumbs (a crawler gave this advice) :confused:
So i'd rather just hear everyones advice and see if other people agree or disagree :)
keep your thumbs out of the center of the wheel, i almost like to cup my hands on teh wheel and make sure nothings inside that area... the wheel jerking can and will happen.
also i prefer a steady pace over whoops, if you have the power/travel you can keep on it hard but alot of the time you dont so you have to find the medium that isnt beating you or the vehicle up.
jumping and holding throttle is actually ok, it just doesnt let the nose of the vehicle come down as fast, rear wheels can land first... theres situations where you want this, if jumping down hill a quick tap on the breaks then the gas might be ideal to bring the nose down quicker.
also forgot and this is actually a bigger thing that you might realize..
keeping throttle down loads the suspension (just like a dirt bike) which m eans your truck will be stiffer going through stuff, if you let off right before you hit the obstical your vehicle will be a tad looser and the valving may not seem as stiff. try it on a bump on the road that you know of, ie a pothole or something, hit it once full run and another time let off the gas before you hit it... the shift in weight makes a huge difference
Keep your thumbs on the outside, if you hit a rut that's big enough to fubar your steering it's big enough to fubar your thumbs too.
Whoops, I keep it at a steady speed unless the terrain calls for more throttle/brake depending on how the whoops are spaced out and if they change in size/shape at all.
For jumping, I found it best to keep on the gas until "take-off" like Corey said letting off tends to make the nose dive down and you don't want that. So it's best to keep a steady throttle and once your off let off the gas/brakes. Think about landing with a higher RPM, your wheels won't be able to spin and keep up with the drivetrain and something will break. It's also best to not apply the brakes either while the suspension is cycling when you land, that's when shit starts to bind. No bueno.
My best advice is experience and/or co-riding with someone who's had more experience and is a good driver. Over the years I learned most of my stuff from Rojodiablo and Belk so I guess you could say I've had some pretty good teachers :D
pedal to the metal :driving:
if you aint first, you're last...
Tweeter said:
:rolleyes: why am I not surprised...good advice RJ
well thats my driving style... :flipoff4:
thanks DesertTRD and Tweet....and Drab haha
sooo clarifying...going through consistant whoops do i have to pump the throttle on each whoop? Or can i just go through them while holding the pedal half throttle?
Heres a noob Q..when your susp is cycling through whoops and you see a big one coming up, is it better for your truck to take the big hit or try to avoid & hit the brakes....im asking b/c a friend of mine told me to never hit brakes while your bouncing around cause that'll make you roll.
I know most of these questions can be answered by saying "pure driver expereince" but i just want to know what to look out for
Anymore experiences adivce? Bowl carves? etc.
every rig is different. what works for my rig might not work so well with yours. get out there and drive it. youll get the feel for what the truck will want to do
drabnor said:
every rig is different. what works for my rig might not works so well with yours. get out there and drive it. youll get the feel for what the truck will want to do
There you go. Thats all I would have said too. Just depends on your driving style also. Just go try it and start slow, if you cant start slow then get a cage and you'll learn from your mistakes sooner or later ;)
I keep a constant speed (RPM's may vary). May be 50% throttle, may be 70% or 30%, depends on the situation, there's no "set" way to do these things.
If you're in the whoops and cannot brake AT ALL (no flat sections) just let off the gas and downshift if possible. Best to keep your truck in a lower gear (I never go into 4th offroad) so the engine braking can slow you down. That's the only thing you can do, don't hit the brakes and hit a bigger whoop, you're going to break something. Best to just lay off the gas and take it best you can.
Dude a lot of it is experience. That's why it worries me to see some guys throw down mad cash on set-ups when their truck was perviously stock. I started with a stock truck and upgraded as I got better. Just things you can practice is keeping an eye on not what's 10-20 feet in front of you but 40+ feet in front of you. A lot of it is planning ahead and having experience on how your truck handles. I can't tell you how to drive cause my truck is WAYYY different than yours, no 2 trucks are alike. Since I'm locked full-time in the rear my driving style is a lot different than most guys on here. You could find a truck that looks just like mine and I promise the valving will NOT be identical and they will be valved to the driver's preference. Just have to learn these things yourself, or co-ride with someone who has more experience :2cents:
Sorry for the novel :cool:
SCEXPLORER said:
Subscribing to this thread. I asked this question in the newb section after our first Barstow trip. But these are better responses than what i got.
http://www.ttora.com/forum/showthread.php?t=55932
ok as far as if you are in a whoop section and see a larger one and cant brake for it, if you try to brake your going to nose into that one so i always find that if i see one like that and you cant do anything about it i would rather keep on the gas or give it more gas to try to get the front end to come over it. letting off the gas softens up teh front and most likely you will plow into it. as far as throttling up and down thats a big no, your drivetrain is already going to be going through enough shock as it is with the tires making and losing contact, to pop the throttle as its happening will load it up more and cause alot more issues. just keep it steady.
best advise i can give is drive at your capabilities, if you find yourself feeling like your getting beat up, your driving your truck too hard and shit is going to break.
every truck ive ever rode in, if the truck felt good it wasnt getting beaten. but if it felt really rough and threw you around then its not good for teh truck either.
planning ahead like tweeter said is very important. Even driving it slowly at first, then going back and speeding it up, etc.. is great too. Just like Tweeter said, every rig is different and will perform very different as well. If you take the approach of taking your time and constant repetitive driving is key. If you can ride with someone that is experience and see, that works too. But one thing I have learned over the years, Take your time and keep on it. Dont think pro's at any sport learned overnight.
Whoops what works for me depends on your ride. On a LT truck that can handle more up and down, you can drive faster. I like to throttle consistantly through the whoops. You can also try throttling up and over the whoops and then taking your foot alittle off when you go down.
For the jumps you can keep on the throttle so you get load on the rear when you land.
PS. Dont do this if you cant plan this before hand and know what is in front of you. Most drivers "prerun" a course to know every detail and to know what to do..
Hope this helps.. I will probably get flammed since people dont think Im worth anything, but I dont care.. lol
Not flaming, just constructive criticism. I wasn't sure what you meant exactly, but it's best to let off the throttle mid-flight, winding up RPM's in mid air then having your drivetrain in shock when the wheels hit WILL break something I guarantee it. Same goes for brakes. I've seen many 3rd members grenade themselves doing this. Especially Tundras with stock rears. That is all :xsmokin1:
-Your Friendly Dezert Mod
Yea, and if for any reason you catch air on pavement... DON'T land with your foot on the throttle! I've seen front cv's break at the dunes as well by landing while you're pinning it.
Also, if you have time to modulate your throttle for every whoop, you simply aren't going fast enough for driving technique to make any difference.
drive smooth, dont spaz out.
control the throttle it is your steering and braking
look far ahead plan your lines, pick em well(this takes ppractice, lots of it)
and as said never hit the brakes in whoops you are better off clearing acouple plus its sick gnar.
The single most important thing I think is to be able to read the terrain. Looking for changes such as g outs, rocks etc is as simple as looking for changes in dirt and plant color. you just have to invest the time for the knowledge.
Mike
I race bikes in the des so picking lines comes very naturally.
Someone briefly mentioned it...but when you have the chance, check things out before you hit them full speed. I go out to Pismo a lot but every time I'll take a few laps down sand highway before I get on it just to look for spots that could be trouble like slipfaces and such. The wind is always changing everything out there, sometimes overnight, so always take a look when you have the chance.
1 - 20 of 49 Posts
