1 - 14 of 14 Posts
So looking at doing a diamond front axle for Felix. Just looking for feedback. What do those of you that have them think? What would you do different or is it perfect the way you have it? Thoughts or comments welcome.
Go with Ruffstuff; the diamonds we've had had surface imperfections on the mating surface for the third member. Roughly finished and leaky.
That may have changed by now, I don't know.
I just looked at rough stuffs axle. Its ok. Ill have to find some reviews from people who use it. Did I read it wrong or can you only use 4.10 gears? Or is the 4.10 thicker than lower gearing?
I think what it says on ruff stuffs site is that 4.10 is the largest ring gear toyota uses and it has 1/4" clearance so anything else would have more clearance and fit better?
thats what i got out of what it said
That blue fj40 we built had stuff axles and either 4.56 or 4.88 gearing... I can check next week. It sure as shit wasn't 4.10.
lol have you even wheeled it?
Yep its been out. We found a lot of metal in the diff so we are looking at upgrading the housing when we rebuild the front end.
if its a brand new gear set, you will find metal shavings in it until it has been broken in.
I'll pick up that Lok-Rite when you're ready; this Detroit is rough on steering.
I thought about it, and that front axle was complete when I bought it; the rear was a third. I put new oil in both when they went under Grond; I have no idea where any metal could have come from. :confused:
I love mine. Haven't had a single issue with it. No leaks or alignment problems. Brian was 100% spot on in all of his setup. I have bashed the diff in to rocks and hard and it hasn't dented even. No issues with 3rd fit or leaking. Top notch quality and I would buy them for everything i own if i could afford it.
Some people have had long wait times so if you order it don't expect it tomorrow. I wanna say 6-8 weeks would be a good guess but it depends on how busy he is. Its worth it. i wish i had gone wider on mine so when you do it make sure you get what you want the first time.
Its a used set and a lot more metal came out than fluid. So before we damage the locker or do more damage we will rebuild it and just redo the housing with a better one. We have already ordered new axle brackets for the links.
Thanks for the info.
1 - 14 of 14 Posts
