1 - 20 of 20 Posts
so im trying to take the stock breather off with a 14mm wrench and starts to strip:scared:
it strips some more and im coming to the conclusion the wrench isnt working, now im trying the vice and its even slipping a little, im about to just give up any advice would be appreciated.
Banned
Grab it with some vice grips and be a man about it. You might also try spraying some penetrating oil on it.
if the vicegrips dont work try some craftsman bolt outs... they rock!
i have this problem all the time! LOL i just spray some pennitrating oil on it, let set for a while, and get my pliers.
It always works.
okay i appreciate all the help, i want some damned Pb blaster thatll help
if its stripped, get a size smaller
god damn your a fuckin riot!
Dude..what's wrong with getting a smaller size?? Perhaps Muddintaco didn't explain himself well enough.....
If you use a file and grind off the stripped parts and make a couple new 'flat' areas for a smaller wrench to fit on it....
Discussion Starter · #16 ·
i thought id just tell everyone i just finished it last night as soon as i got the breather off it went smoothly from there on out, i routed the fuel line up to my gas cap, just thought id tell everyone, thanks for everyones help.
Bray how do you like those mtz's/// this is a jack and a pad:rolleyes:
Josh, is that you? I'm liking them pretty good. They shed mud very well and are soft enough to grip on wet and dry rocks at about 10 pounds---and I'm gonna try 8 pounds next time on a run. They howl on the highway but ride great. I think it's about time for me to rotate them. Oh, I need gears too!
yeah it is me... I am sad to hear your sons flag should be at half staff.. Damn humans. Good my BFG MT's suck in wet roads even sipped. I think I might go with some aggrssive AT this time around. you going to go with 4.56's?
That's why I carry a 24" long one?
Daaayuuum! 24 inches? I feel like I have to 'short-stroke' it with my 14 inches. And if I push it, she says "Whoa!". I would only suggest using your full 24" from the rear. Are we still talking about our trucks? :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Man, I'm hearing good things about Nitto Terra's. That is what I'd try to get as far as A/T's go.I've had bad luck with 2 sets of BFG A/T KO's. The treads look pretty aggresive and are very high quality on the Nitto's. As for gears, I'm torn between 4.56's & 4.88's. Good to talk to ya!
1 - 20 of 20 Posts
