1 - 12 of 12 Posts
Hey..I've got a 95 T100 automatic 3.4l 4wd and I need to know if my rear diff has 2 or 4 spider gears in it?!?!?I'm replacing the pinion seal and I need to know to set the preload! thanks for all the HELP.....
That is close and has a lot of info....but I still can't seem to find if my truck has 2 or 4 spider gears in the rear diff?!?:eek: thanks ...anyother suggestions? or guesses?
my code is C/TR 045/FF13. A/TM A10a/A340F I think I figured it out though its a 2 spider gear...
Deal Master
Why would the spider gear design make a difference when setting pinion preload?
Discussion Starter · #7 ·
I'm not to sure...I've never replaced a pinion seal and I am using the Chilton repair manual to repair/replace my leaking pinion seal and Chilton says in step 8 of To Install: "Check the drive pinion preload with a torgue wrench. For Pick-Ups and 4Runners, correct torque is 8-11 inch lbs.(0.9-1.2 Nm) for 2-Spider gear differentials and 4-7 inch lbs. (0.4-0.8Nm) for 4-Spider gear units. Land Cruisers should be between 6-9 inch lbs.(0.6-1.0Nm)"
thanks again
Deal Master
thanks again
I don't even waste my time with Haynes or Chiltons anymore
The 4wd Tacoma/T100 rear diff is a 2 pinion spider gear design-
According to my Toyota FSM- 1999 Spec for the rear diff is 5.7-8.3 in*lb
A T100 rear should be the same
In your case - You should measure the the Pinion Preload before tearing things apart to get the current pre-load. Use this as a reference as well
How are you planning to measure preload? Were you planning to replace the crush sleeve as well?
Discussion Starter · #9 ·
I'm going to measure the preload with an inch lbs torque wrench and what do u mean by the crush sleeve??
Deal Master
Not sure on the success rate of simply changing just the oil seal-
Once you remove the staked nut- their is chance of further deformation of the crush sleeve when you put things back. I always keep spare crush sleeves on hand- However- Now you have the opportunity to use a sloid spacer for the Non-TRD/T100 Diff
http://www.tacomaterritory.com/forum/showthread.php?t=47748&highlight=solid+spacer+8.4
FSM Reference
http://www.deserted1.com/FSM/Repair_Manual/03tacoma/sa/rdfos/repl.pdf
According to the Toyota Factory Service manual - Once you remove the staked pinion flange nut & flange- They instruct to remove pne of the pinion bearings and install a new crush sleeve, reinstall the bearing , new oil seal etc.....
Edit- If its good enough for Zuk
- its good enough for me (for a Simple pinion seal change
http://www.tacomaterritory.com/forum/showpost.php?p=794672&postcount=11
Usually A good rule of thumb: Mash the throttle on your impact gun till the pinion nut stops turning....Then go till it explodes.then upgrade!:rolleyes:
No really...most of the T-100's were 4:10 double spiders with the reinforced carrier caps like the Tundra/Sequioa
Discussion Starter · #12 ·
Right on...so i changed the pinion seal with everyones help and it went in great...i had to make a couple of tools but it all worked out....i also put in some extended diff breathers too...thanks for everyones help now i get to test it out at BR trip next weekend..
1 - 12 of 12 Posts
