I was wondering if anyone has had these in 15x8 and what BS you used. If I plan on 3" suspension and 2" body, will it fit 33's on 3.75 BS. I have an 02 tacoma 4x4. I'm willing to bang pinch welds and all that, just worried about fender issues. HOw about 4" BS? Will that tuck nice. Mainly work truck. I wish the centercap came in black. Does anyone know of similar looking wheels? TIA.
http://www.4wheelparts.com/4wp/prod...cat=WHE&prodline=3204&catName=WHEELS&man=TECH
with 3" suspension and 2" body you should be fine with either BS
Will they fit though
Are these on your rig? I heard issues with these fitting (15x8) on the other board. I'm really leaning towards these. I guess the only BS available is 3.75 or 4.5. How does 4.5 look? Tucked like stock? I'm planning on a 2" RB BL and 3" spacer/AAL. The lift I could deal with, it's just knowing if these wheels will rub the caliper is what I'm worried about. I prefer them sticking out just a bit.
i have those rims in 15x8 w/ 3.75" BS...they clear the calipers and stick out just past the flares
Re-Member 9/11
With 4" bs spacing and 33's you may rub on the control arm. Go with the 3.75" bs. I have heard that the 97 series wheel underwent some changes and will not fit your 02 without grinding. Check out www.wheelersoffroad.com . He sells the 87 series procomp rock crawlers with a 3.75" bs that fit my 04 without any problems.
my rims are procomp something or other (same as wheelers) and i got them from 4wheel parts...they ended up being a lot cheaper than wheelers because they gave free shipping and a free lug nut/valve stem kit...actually now that i see the part# in your sig i've got the same ones as you
