181 - 190 of 190 Posts
Apply some heat and beat it straight with a hammer, it'll run fine. :D
I guess that explains why it was running bad. Did you do this, or do you believe it was PO damage?
Discussion Starter #185
I'm thinking that the bad head gasket led to water getting on top of the piston, which bent the rod. The cylinder wall still looks good, so I am running with the assumption that there are no other major problems and putting it back together. A new piston, rings, and rod bearings on cyl 4 along with the new head gasket should get it back on the trail. Eventually I'm going to have to stop throwing band aids at this motor and come up with a permanent solution for my aging 360k mile 22re.
Discussion Starter #186
It's alive!! Had to replace a bunch of rubber hoses that swelled up bad b/c of the oil running through them. Rod bearings on cyl 1 and 4 looked like crap again, but it's been almost 2 years since I put that set in without machining the crank. Threw a new set of bearings at it and hopefully I can go another 2 years before tearing into the motor again.
I just bought this rig and drove it home 3.5 hrs haha. I did run into problems with the front axle on the passenger side. Going to tear it down tonight to see whats up.
Discussion Starter #189
It's a great rig. I considered buying it back not long ago. I can't believe you drove it that far! How did it do? Hopefully you keep it longer than the other folks have. It's bounced around a lot since I sold it. :(
It did great till that brake caliper started locking up I thought it had something wrong with the hub but ended up just being a caliper. I had it running 60 never got hot and only used a half a tank of gas. It does have couple leaks on the t-cases but other than that its great. rode rough as he!!. Did you balance the tires with BB's? I also love the rear bumper you built for it.
