I recently bought some used Donahoes and am having issues installing them. The drivers side coilover went in just fine, but the passenger side coilover is giving me issues. I sent Donahoe an email regarding the problem, but thought I would check to see if someone could help me out on here.
On the drivers side coilover the schrader valve was pointing straight out (as I believe it is supposed to be). However, the passenger side was different. Due to the position of the lower bushing the schrader valve was facing toward the cab and was hardly accesible due to the strut mounting plate (metal on truck). So, instead of the Dr logo (and valve) pointing straight out, the hole about an inch to the right of the valve was lined up with the front mounting hole. Is there anyway to adjust the coilover on the upper or lower portion so the schrader valve is aligned with the center... Maybe I haven't explained this well, so bare with me please. Thanks!
