1 - 2 of 2 Posts
Well, never thought it could happen but it appears both segment of my drive shaft are making squeaking noises. Appears to be coming from inside both segments. They are hollow no question. Is there some other material that could have vibrated loose and come apart causing the noise. I removed the front section and it appears the ujoints are ok. Also where can I order a good replacement.
2000 extended cab v6 auto trd Tacoma
How do we arm the other 11??
I had the same thing happen on my 2003 Extra cab 4wd . I just greased the $hit out of all the universal joints and it was solved. Just remember if you have the double cardan joint , I thinks its called , there is a few grease fittings that are kinda hidden . Make sure you grease them ALL . This is way cheaper to try first before you spend money on a new shaft or joints.
1 - 2 of 2 Posts
