Does anyone use a dual battery system? If so what brand, what to look for in general? Thanks
I run 3 batteries in my truck. two SVR-80's in the back, and a Optima Bluetop under the hood. All powered by a high output Iraggi 220amp alternator of course.ohbejoyfull said:Does anyone use a dual battery system? If so what brand, what to look for in general? Thanks
cuz of all of my lights & winch. Ive drained accidentally 3 times alreadyvolley said:Just out of curiosity, why is the yellow top your starting battery and the red top your back up and not the other way around? Not being a smart a&& just wondering for my own little information bank..
I'll be doing the same thing. I have a Waeco portable fridge/freezer out of my old truck. Going to use the Yellow Top to power it and my very very modest stereo system.ZR2Steve said:I'm running a dual battery set-up to power a fridge. I've been using the Surepower Isolator for about 3 1/2 years now.
Bajataco.com has a write-up for his set-up.
thats a good way of looking at it, i think i may just go that way when it comes time for it.TMS2U said:Yeah, that way I will always have a fresh backup batt- but you can do it the other way as well. It will come down to what type of isolator/combiner you use. The HR set up provides a trickle charge to the BU batt so that it is always fresh, but does not pull on the alternator that much. If I drain the primary, all I have to do is flick a switch I have new juice. By using the deep cycle as the primary I dont have to worry about draining it as that is what they are designed to withstand. The CCA are pretty much the same with the red & yellow optima (the red is higher I think)
volley said:You remember where you got the Sure Power from?
Check out www.bajataco.com - He has a nice dual battery setup and a write up.ohbejoyfull said:Does anyone use a dual battery system? If so what brand, what to look for in general? Thanks
Where did you buy your HR isolator?? ThanksTMS2U said:Yeah, that way I will always have a fresh backup batt- but you can do it the other way as well. It will come down to what type of isolator/combiner you use. The HR set up provides a trickle charge to the BU batt so that it is always fresh, but does not pull on the alternator that much. If I drain the primary, all I have to do is flick a switch I have new juice. By using the deep cycle as the primary I dont have to worry about draining it as that is what they are designed to withstand. The CCA are pretty much the same with the red & yellow optima (the red is higher I think)
The Dual battery page isn't up yet from what I can tell. Trust me, I've been eagerly awaiting for the battery, compressor, and electronics pages to be open for awhile.4xClover said:Check out www.bajataco.com - He has a nice dual battery setup and a write up.
